David,
Tks for updating us! It is both good news that the car seems ok and somewhat expected IMO. ZF boxes do seem to have a habit of draining back and that can cause some unexpected symptoms when first starting up until valve blocks, torque converters etc are re-primed. I'm sure it's a relief to you that things do seem to be ok for now.
So, although it's good that the car seems to be ok. I'm sure you'll want to to try and ascertain where the leak came from. I suspect you're going to have to try and degrease the box as much as possible to to try and see where the leak may be.
Do please let us know how you get on
Transmission failure 3.2 litre Sovereign
Re: Transmission failure 3.2 litre Sovereign
Good news then.
Perhaps some regular use will help keep the cogs well oiled?
91 4.0 XJ6 Manual
92 4.0 XJR Manual
93 3.2S-4.0S Man conv
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
96 X300 Daimler Six LWB
97 X300 Sport 4.0 Manual
00 LR Discovery 2 TD5 ES A
03 X350 4.2 XJR
92 4.0 XJR Manual
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
03 X350 4.2 XJR
I thought I should follow this up now that a fair bit of time has passed since 'the event'.
Anyway, I have had no further problems with it - and it stopped leaking immediately after the problem and has continued to be leak free. I had it checked out by a specialist - who could find nothing wrong with it. So a one-off and a lucky escape for me there!
(XJ40) 1992 Jaguar Sovereign 3.2 (93MY)
