Break down
sean
Break down
Postby sean » Sat Dec 12, 2009 3:09 pm
Hello,
I was out last night and the car started to misfire at about 40mph, got to a set of traffic lights and I thought it would stall, however it ran smoothly, then about half a mile later it broke down and would not start again. it was cranking but would not even fire. I live at the bottom of a hill and managed to push it a little then managed to coast all the way onto my drive (phew).
Came out this morning to have look if something simple as the car has very recently been serviced (less than 50 miles ago), and it will now not crank. I have good battery voltage 12+ and also tried a jump start to try and crank. It is as if the inhibiter switch is working (as if in drive but no warning noises)
Not sure if it is connected but the alarm warning 'chirps' stopped working a short while ago. Tried both keys .
(this could be a red herring though)
Car is a 4L Soverign lbw with 73k 1997 (straight six)
Any help appreciated.
robv12
Postby robv12 » Sat Apr 03, 2010 3:51 pm
apologies I missed this post. have you got the problem sorted, if so what was it, if not do you still need help??
