Engine Speed and Hot Starting
bossred
Postby bossred » Mon Jan 29, 2018 3:52 pm
My 1996 X300 , 3.2 Sport starts fine and tick over around 700 rpm and after a short journey I stop and start again which brings it up to running temperature , but the tickover has now increased to 1300 rpm.
If I then switch off and got eg. a shop , it will not start , but after 10 or more minutes it will start. ANY IDEAS ?? Crank Sensor ? - Throttle Body ??
Chris :?
Popsjag
Re: Engine Speed and Hot Starting
Postby Popsjag » Fri Apr 13, 2018 1:17 pm
Hi Chris,
I would suggest looking at the throttle body, especially the TPS sensor (black part under the throttle body). This may be worn and sending false positions to the ECU.
2003 X350 XJR - daily driver
Past vehicles:
bossred
Postby bossred » Fri Apr 13, 2018 4:38 pm
Hi There,
Many thanks for the info , David Marks also suggested that :( and My Mechanic hooked it up to his Computer and it did seem to suggest that so I have got a replacement to try .
I will put a post up if it works , Fingers crossed.
Chris
Popsjag
Postby Popsjag » Mon Oct 21, 2019 8:47 pm
This topic has been moved to the 'Engine' Section.
Past vehicles:
