Setting valve clearances
Posted: Sun Jun 05, 2016 7:53 pm
Hi Everyone
This is my first post having recently bought a 3.2 X300.
It is a beautiful car in every way except that the engine is lumpy, the seller advised of this and had spent quite some time and money trying to find a cure.
The first thing I did once I got it home was to check the compression with the engine cold and the results were not good, No 1 and 6 being considerably lower than the others at 7 and 5.5 bar respectfully. So next I checked the valve clearances and 3 inlet valves had no clearance at all.
So, I need to get most of the valves re-shimmed (some are in spec) and anticipate a garage will charge about what I paid for the car to do them. I am perfectly capable of doing this myself, but of course I don't have a vast selection of shims to choose from. I can't even calculate what size I need for the 3 with no measurable clearance so will have to do those by trial and error 1st time round.
So to get to my question. What are my options? Is there a way of borrowing shims and buying those I eventually use?
Cheers for now.
Glen.
Cheers for now.
Glen.
