My beautiful but unreliable XJC is once again misbehaving. The engine starts first time, fires, then dies immediately. This is a 4.2 XK with twin SU carbs.
I can hear the fuel pumps running and the filter is visibly full of fuel so the theory runs its a spark problem.
There is an absolute buggers muddle of wiring around the distributor etc etc any and all ideas welcome. I've checked the LT connections and the relays near the dashboard.
Help...
Alex
XJ6 not running fires then dies
sadly this sound as if it's one of those problems where i would need the car in front of me
I would be checking quality and age of fuel, fuel pressure, condition of carbs
on the ignition side, coil, dizzy cap and rotor, plug and king lead
i would also suggest a post in the XJ series BB as this is really the correct place, you may just get a tad more info from the guys on there
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
