Retrofitting parking sensors
maxbozon
Postby maxbozon » Fri Aug 14, 2015 12:41 pm
Hi!
I am thinking to retrofit some parking sensors both front and rear. I've seen a few reports of people even fitting cameras in the magazine.
I would be grateful if you could share your experiences and advice.
I am particularly curios about the front parking sensors. Is there a way to automatically disable them when car is moving faster then certain speed? Or enabling them only when it is in 'D' and the foot break is pressed works OK?
What are the better options in terms of quality and longevity?
Thanks,
Max
X300 Executive Auto, 3.2L, 1997
PeterDavisX300
Re: Retrofitting parking sensors
Postby PeterDavisX300 » Wed Aug 19, 2015 1:31 pm
Hi. I fitted a set of 'Ultrasonic' parking sensors off ebay about £35 to the Rear of my X300. An easy fit because the Jaguar has good spaces in the rear bumper, and a lot of space around the rear fuse compartment by the Battery. The ones I got were colour coded from the supplier for no extra cost, I just supplied the Jag' paint-code. The kit comes with a hole-saw that fits to a drill-chuck, and also comes with everything one needs. A friend who has fit a set of the same type to the front of his Automatic car, took his feed off 'First-Gear' position. So' when in first-gear to move forward, the sensor was activated, but not when the car was in 'D'.
Hope that helps
Peter
1984 Mercedes 450SL Rag-Top
maxbozon
Postby maxbozon » Sat Aug 22, 2015 9:57 pm
Hope that helps
Peter
Hi! Thanks for the reply! :) Well, they will obviously need to be ultrasonic ones. It is very cool that you can get them painted in the right colour! Could you PM or post here which seller did you use?
Just to clarify with the front ones. What is the 'First-Gear' position? Going along the 'J' from the parking position: P-R-N-D-D-3-2... Or is there any wire in a harness somewhere which tells that it is the first gear now? I didn't look into electrical circuits yet...
Thanks,
Max
PeterDavisX300
Postby PeterDavisX300 » Tue Aug 25, 2015 9:51 pm
Hi Max.
You're lucky, below is the link to the exact sensors I used, fortunately for you there is now so-much competition in this field that they are now a fraction of the price I paid for them!
http://www.ebay.co.uk/itm/Reverse-Rear- ... 20d690b4ba
Regarding fitting the front sensors, I see exactly what you mean! I also own a few other 'older' cars, one of them a 1998 Ford Scorpio Ultima, (NOT a Granada!) This car's Auto-'Box has a First-Gear-Position as in, 1,2,D then O/D (overdrive) It was one of my colleagues on the Scorpio-Site that had fitted them to the front of his car and wired to First-Gear straight under the selector. (Each selected gear sends a message to the ECU on this vehicle, so power-feed can be taken from here) Now there must be something similar to that on the ZF transmission, because the French AD4LE is a very similar transmission that was copied from ZF which also uses a locking-clutch to give 100% drive.
Peter
maxbozon
Postby maxbozon » Tue Aug 25, 2015 10:35 pm
Hi Max.
Peter
Hi Peter!
Thanks very much for your reply. So I have looked into the electrical circuit of the transmission and it looks like I can see how to make things right.
Right at the body of the transmission control unit, which is located at the front under the hood, there is a multipin connector used for diagnostic purposes. Among other outputs it has got a pin with 'road speed' and 'gear position indication'. So all I need to do is a small circuit with basic relay logic : "If Voltage of road speed is below X volts and gear shift voltage = Y volts then activate parking sensor". Since I want it activated only when moving slow and forward.
It might be a bit tricky to find the connector though... and also it is not clear to me what are the actual voltages...
I wonder if anyone had any experience with these things?
Here is the link to the bit of X300 manual: https://www.dropbox.com/s/svq4fjyd1xmzz ... f.pdf?dl=0 look at section 8.1 pages 1-3 and 10.
Max
