Thanks Andy and Rob for your replies.
Here's where we're at...
The Battery was disconnected and on charge for a few hours yesterday afternoon.
This being after pressing the VCM button and reading "FAIL" on the display. I then proceeded to physically check all the fuses in the three fuse boxes. They all looked fine. I then reconnected the battery again last night at about 9pm. all seemed fine.
Checked again thismorning before taking the dog out, still ok. Checked an hour or so later, and the high pitch whine was back, along with the above symptoms - it's definatley from inside the car.
I pressed the VCM button, and the display read "fuse 1". I decided to start the car - no probs starting - and then cheched all the lights. The O/S/R tail light and O/S number plate bulbs were not working, which lead me to the 3amp fuse in the RH fuse box (C3), for the "RH REAR LAMPS-TAIL, SIDE MARKER & No. PLATE". It still looked ok, but I've changed it and the lights are working again now.
Also since then, the high pitched whine and above symptoms haven't come back.
Coincidence
or is there an audible warning device fitted to indicate a blown fuse I wonder....
I'll let you know if alls not well when I get back next week...
Best regards, Jona29.
P.S. At least I've managed to fit the new aerial mast I bought from Car-Masts-UK, which was all I thought I'd have to do before going back to work tomorrow
1991 (J) XJ40 3.2 Auto. Duel LPG. Jade.
1990 (H) XJS 5,3 HE Auto. Burgandy.
