AJ16 engine stalls and gearbox goes into limp-home mode
Posted: Mon Aug 02, 2010 9:14 am
Hi All,
After many trouble-free miles, my X300 Daimler Six has developed an annoying problem.
The intermittent issue occurs when approaching a junction such as a roundabout. The engine correctly idles whilst braking from 20-30 mph but can then stall at around 10 mph. The dash lamps then light up (expected), I slide the J-gate shifter into Neutral, pull the key back to position one, then re-start the car (an audible beeping is heard momentarily). The car restarts, but limp-home mode is activated (transmission lamp is on)! This is very annoying and dangerous at junctions! Fortunately, it has only happened twice so far. I have taken it to a Specialist who was only able to find a Stall code on the ECU - so nothing else to really go on. Both Stall events have taken place over four days. I should point-out that leaving the car for 5 mins or so seems to reset something as the gearbox is no longer in limp-home mode upon starting.
I had a quick search and so far the Transmission Control Module and the underneath pin connection have been cited as potential issues - I'll check these soon.
Any ideas / suggestions folks? The car is my daily runner.
Many thanks in anticipation, Rich.
