digital clock
richm1
digital clock
Postby richm1 » Wed Feb 17, 2010 12:51 pm
can anyone help with my digital clock, i cant read it !!! it lights up well enough but the numbers are all unreadable , on my previous car (scorpio cosworth) i had trouble with the display on the the stereo, so i was told to remove it , put in a bag then leave in the freezer overnight , and lo and behold it worked!!!! will that work on the clock or is there another way to solve it?
aidex300
Postby aidex300 » Fri Feb 19, 2010 12:04 am
There is a bod over on ebay. that claims to be able to fix this problem? never try'd but have the same thing with mine. :(
richm1
clock
Postby richm1 » Sat Feb 20, 2010 10:08 pm
might try that , you dont realise how often you look at a clock until you aint got one!!!!
davidkiddey
Fixing digital clocks
Postby davidkiddey » Fri Feb 26, 2010 2:36 am
I found instructions for dismantling the digital clock and fixing the display at the Jag Lovers Forum http://www.jag-lovers.org/ It takes a bit of time but it works. I got mine from having only three bars working to having only one bar that doesn't work. I've still got the instructions so email me david@extranz.com if you can't find them at Jag Lovers.
