Hi, I have a right hand drive X300 1997 Sovereign, I have a problem with the Near Side (No problem with Off Side) indicators - selecting either the near side indicator or the Hazards - all appears normal inside, however there are no bulbs flashing outside…. I have checked the bulbs = all ok.
Looking at the wiring diagram and it shows diodes FC59 & FC60, one for each side - anyone knows where these are located as would like to swap them….
Any ideas would be great fully appreciated. John
X300 indicators on NS not working Off side Ok
Re: X300 indicators on NS not working Off side Ok
Up date - it’s fixed - turns out it was a broken wire between the Lamp Control Module and the and the Body Control Module (YS)… this was replaced and the diode connection was added to this new wire.
Never did find the actual diode unit….
