xjr6 wont start / crank
petemos
Postby petemos » Wed Apr 25, 2018 4:28 pm
Peter Mosgrove
Just now
Ok, so I have a 1996 xjr6 manual that wont start. It hasnt been started in a few years. when I loock the car either with key or fob it opens and locks about 3 or 4 times before locking. Absolutely everything works gauges etc...engine check light comes on and goes out..from what ive read that means immobilser problem......the cooling fan comes on with the ignition...battery is producing 12.38v .......also a wierd thing is that the white wire to the solenoid has a constant live feed wether the ignition is on or off....i thought this would only be live when turning the key to start............engine wonk crank....any ideas people?
robgx300xjr
Re: xjr6 wont start / crank
Postby robgx300xjr » Tue May 01, 2018 2:04 pm
I am no way an expert in these areas - but have you checked the crank shaft position sensor - if these fail (I have had 2 genuine parts fail) the engine won't turn over.
1997 XJR X300 Manual
robv12
Postby robv12 » Fri May 04, 2018 2:06 pm
solved, via another forum, ECU failure, water ingress, and I met Peter the other day on Jedburgh!!!
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
Users browsing this forum: No registered users and 24 guests
