Schoolboy error
kmorrison2011279
Schoolboy error
Postby kmorrison2011279 » Tue Feb 11, 2020 6:16 am
Hi all, 1997 X300 Sovereign, bought last year cleaned it then put it away over the winter, yesterday I went to check on it and guess what I've only gone and left the battery connected. Battery is totally flat won't operate the central locking, how an earth do I get into the boot to replace battery or is there any points in the engine bay where I can hook up a battery to operate central locking?
Any help would be good thanks.
cafcpete
Re: Schoolboy error
Postby cafcpete » Tue Feb 11, 2020 8:17 am
Does the key not work in the boot? There should be a key hole next to the badge on the right hand side.
Peter
1996 Jaguar XJR6(auto)
2002 Jaguar X350 4.2(auto)
kmorrison2011279
Re: Schoolboy error
Postby kmorrison2011279 » Tue Feb 11, 2020 8:31 am
Thanks Peter, I honestly couldn't see any key hole, will have a look and get back to you
cafcpete
Re: Schoolboy error
Postby cafcpete » Tue Feb 11, 2020 9:10 am
It can get stuck though lack of use, but if so keep blasting with penetrating oil and rocking the key in lock. That surely frees it of!
You are not the first, if the key fails read here
https://www.jaguarforums.com/forum/xj-x ... pen-51519/
Another write up
http://www.jagrepair.com/TrunkAccessDeadBatteryxj6.htm
Peter
kmorrison2011279
Re: Schoolboy error
Postby kmorrison2011279 » Tue Feb 11, 2020 9:52 am
All sorted thanks Peter, found the key hole and thankfully it wasn’t seized Battery now on charge😀
cafcpete
Re: Schoolboy error
Postby cafcpete » Tue Feb 11, 2020 10:07 am
Excellent news!
