Hi!
Recently I had to replace the nearside headlamp unit on my X300. The replacement is a used one off an X308. Once in place it looks like the light is not properly aligned, but I am not completely sure about this: I noticed the asymmetry of the beams even before, but I can't recall how did it look.
So here is the picture of my dipped beam on the wall approximately 4-5 metres away:
You can see that the left nearside beam is higher and at a distance, I think it also points more to th right.
And here is the main beam (together with the dipped):
This one clearly points to the right of the straight axis and significantly lower.
My question is: should it be like this? If no, how to adjust it?
Max
P.S. I know it is a stupid question, but is there a way to clean the headlamp lens from inside?
Aligning lights
X300 Executive Auto, 3.2L, 1997
Re: Aligning lights
In the meantime I managed to fix this myself. I took a small risk (of breaking something) and started fiddling with things. It appeared that the adjustment is quite trivial.
Taking the picture from Jaguar Classic Parts. Arrows show which knobs to turn. Apparetly is it OK to adjust electric motor position for the dipped beam. It sets the anchor point and them moves within the range when set from the control inside. With the main beam it is simply a screw. Both of them are made to be accessible without tools.
But here is another question: did anyone ever tried to polish the front surface of lenses? to get rid of the small stone-chips.
