Bulb light on dash
Car-Nut
Bulb light on dash
Postby Car-Nut » Tue Aug 09, 2011 4:35 pm
All my bulbs work fine but the bulb light on the dash is on :?
Any ideas
Clive
(Car- Nut)
MK7, 8 & 9 Forum Co-ordinator
MK10 420G Forum Co-ordinator
:arrow: 1970 - 420G - WiP
:arrow: 1962 - E-Type FHC
:arrow: 1997 - X330 4.0
robv12
Re: Bulb light on dash
Postby robv12 » Tue Aug 09, 2011 5:18 pm
often a wrong rated bulb can cause this fail to show up
also check side repeaters for corrosion, check both rear number plate lights are on, also check both front indicator bulbs are good, each one has two bulbs
some pointers for you to look at this weekend!!
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
Car-Nut
Postby Car-Nut » Tue Aug 09, 2011 5:53 pm
Cheers Rob, I'll add it to the list after the E but before the 420G
Clive
(Car- Nut)
Car-Nut
Postby Car-Nut » Thu Aug 18, 2011 9:52 pm
Left bulb above reg plate :wink:
Clive
(Car- Nut)
Postby J44EAG » Thu Aug 18, 2011 10:03 pm
There you go.
Jenner is not just good for breaking into cars!
