Front body dismantling finally started
For 'Classic Compact Saloons',
ie Mk1, Mk2, 240, 340, S-Type, 420, Daimler V8 & Sovereign
Moderator:Aceman
steve.pritchard146
Postby steve.pritchard146 » Sun Apr 03, 2022 11:16 am
Have started my 3.8S front end excavation for real - having pottered around the edges and delayed for months, I’ve taken lots of pics and am starting to cut out the rot…
I dropped the front suspension last weekend and will be looking to lower the engine next so that I can commence repairs/ replacement of the front RH chassis leg.
I’m trying to keep the work and scope contained to manageable chunks so that I don’t get overwhelmed but this front area of the car consists of so many discrete sections there is no easy way to repair one at a time.
My main concern at the moment (as well as building back structural strength) is to maintain all the exact suspension and engine mounting positioning/geometry which is causing a little angst.
So I would welcome advice from anyone who has worked in this space
Current:
2001 XKR silver, 2008 XJ Blue, 1986 Land Rover Defender, 1967 3.8S cream
Past:
S500, Porsche 944 Cab, Porsche 928 GT, porsche 944 Lux ,Volvo XC90,Volvo S80 T6,Jaguar XJS v12,Volvo C70,Mini R56 Cooper S,Land rover Discovery, Range Rover V8 HSE
steve.pritchard146
Re: Front body dismantling finally started
Postby steve.pritchard146 » Mon Apr 04, 2022 8:14 am
You can see in the attached pic the view through the drivers wheel arch. Now I have cut out the brace section it’s easier to see that The front section from the engine mount forward is basically Swiss cheese. In fact trying to undo either of the bumper mount brackets moves the chassis. So that is where I need to start cutting out from.
Current:
Past:
