I need to replace the Headlining around the rear screen on my 1965 S-Type
Can anyone give me some advice here on the best way to do it.
Can it be done without removal?
Does the rear screen need to come out to access it?
Any help would be appreciated
Graeme
S-Type Headlining around Rear Screen
Moderator:Aceman
Re: S-Type Headlining around Rear Screen
Hello Graeme,
I would say the screen must come out (Consider replacing the rubber seal on replacement as the old rubber will be past it's best) (Unless recently replaced of course), as the headlining will need to be glued around the aperture.
Hi Alec
Thanks for that.
Can it be done in place with the rear screen removed or will other panels need to be removed to gain access?
Graeme
Thanks for that.
Graeme
