Overdrive
Moderator:Aceman
Re: Overdrive
An inhibitor switch on the gearbox prevents overdrive engagement in anything but top gear. If you bypass/override the switch you can select overdrive in any gear but take great care - engagement in reverse can cause catastrophic damage, and engagement in some other gears would be unwise.
Robbie
Robbie
Daimler Sovereign S1 4.2 1971
