Mk2 electrical problem
Posted: Thu Jun 14, 2018 3:20 pm
by spadekevin
I seem to be having some sort of an electrical bug. Tried starting my car, but just won't start. When switching the ignition on I noticed that the fuel pump don't prime at all, i checked fuse and relay(need to take power straight to the fuel pump to see if it will work).
What i found strange is when I turn the ignition on, the indicator light on the dash is on(but dim), if I switch the indicator on it only goes bright but does not flash( but the hazards works fine). The horn/hooters does not work, but the relay "clicks". Reverse lights and handbrake warning light is also not working, everything worked fine last week friday when I last drove the car?
Please help.
I didn't find the right solution from the Internet.
References:-
https://www.vwclub.co.za/forum/viewtopic.php?t=206934
Cloud Field Service Management Video
Thanks!
Re: Mk2 electrical problem
Posted: Thu Jun 14, 2018 8:27 pm
by JimboV8
Checking your ground points around the car is where I would start. :mrgreen:
