I have recently fitted a 4.2 triple carb into my MK 2 240, I need to upgrade the diff to a higher ratio.
Does anyone know which way to go.
Has anyone got anything, or can anyone suggest anything.
I live in West Yorkshire.
Thanks for looking
Differential
ecosselynx
For a quick fix, you should be looking to pick-up a rear axel out of a 3.4/3.8 automatic, these had 3.54:1 ratio differentials. Or re-build your own differential using a 3.31 crown wheel and pinion out of an XJ differential, this is a little more difficult as you need to get a bearing for the front pinion which is non-standard.
I don't have the number with me at the moment but can get it for you in a Month if you want to go that route. I went that route back in 95 and am happy with it, your pulling 2500 rev at 70 mph as a rough guide. I have heard of people running 3.07:1 differential, but I felt it was to high geared for the motoring I was to be doing.
regards
John H.
regards
John H.
ecosselynx
Hi David
For the 2.4, you may want to consider the 3.77:1 which was used in 3.4/3.8 MOD cars and should therefore be easy to get hold of. I find my 3.4 handles the 3.31:1 quite easy and is not over geared, I can run in 5 gear (same ratio as OD) happily at 50/55. Yes it's better to have your speedo re-caliberated, but I would wait until you try a ratio that you feel suites your car before having it done, just my thought.
If you need any other info let me know.
John H.
John H.
ecosselynx
Opp's
As for down sides. I don't have any, but then I'm not into dragging off the lights. Obviously you initial acceleration is not the same, but were talking 40 year old cars. I make trips from Scotland to France in my car fairly often, leaving jockstrap land 07.30 and catching the 17.00 tunnel, in the two day trip I clock-up 1120 miles, so I'm not getting in anyone road either.
john H.
john H.
