Stainless Steel exhausts
Posted: Wed Dec 05, 2007 9:54 pm
by chrischapman
I am considering the fitting of a SS exhaust to my Mk2. I would like to hear others opinions of the Bell verses Falcon (Falcon standard and straight through) which are available from the two well known parts suppliers that advertise in the club magazine. Thanks Chris :)
Posted: Thu Dec 06, 2007 7:30 pm
by PeteB
We use Bell exhausts (no relation) exclusively, as - in our experience -their products seem to be better made than most, and also tend to be a better fit.
Peter Bell
Posted: Wed Sep 10, 2008 1:39 pm
by petticd
I have recently been conemplating the same, however, "Hayward & Scott" was reccommended to be best of all. They are somewhat more expensive however, the quality is better (I'm told). I visited their site and was taken around the workshop - products look very good. These guys also supply a well known restoration company in Maldon and are also listed in the JEC magazine.
I finally bit the bullet and ordered my system 3 weeks ago, can't wait to fit it!
STAINLESS EXHAUST
Posted: Wed Sep 10, 2008 3:22 pm
by chrischapman
Since my post on this subject I have followed Pete Bells advice and fitted the Bell system (no relation). I found it easy to fit and initially I was disappointed by the sound but now I am used to it. It does not detract from performance as far as one can tell by driving. It's probably better for being quieter because loud exhausts are waring when driving over longer distances.
Posted: Tue Nov 18, 2008 8:54 pm
by petticd
I did fit the "Hayward & Scott" system, including thier SS 6 branch manifold. Very pleased with the product, the quality/fit is excellent. I did have to modify the silencer bracket slightly. I too was disapointed by the noise, completely different sound (louder), as much to do with the manifold as the 50 mm exhaust system itself, however I am getting used to it!
Re: Stainless Steel exhausts
Posted: Sat Jan 16, 2021 8:41 pm
by nj_brown268
Just had my (300hp) mk2 on a Dyno, and the exhaust is getting red hot.
I have been advised to change it to a s/s sports exhaust, with manifold.
Thoughts?
Posted: Sat Jan 16, 2021 8:42 pm
by nj_brown268
Thoughts?
Posted: Sun Jan 17, 2021 9:20 am
by piman
Hello NJ,
changing the material won't affect the temperature of the manifold.
One thing to check is that the ignition timing is not retarded and\or weak mixture as that also will run hotter, as this can increase the manifold temperature?
Posted: Sun Jan 17, 2021 3:24 pm
by nj_brown268
Thanks Alec.
I was under the impression that the exhaust on a standard 3.8 was quite restricted, causing them to run hot.
The idea behind fitting a sports exhaust and manifold was to reduce back pressure in the system?
But I will get the garage to double check the mixture and timing.
Posted: Tue Jan 19, 2021 12:38 pm
by PPV
One way to keep the under bonnet temperature down is to have the manifolds sprayed by Zircotec. They come highly recommended by Practical Classics in the past.
Perhaps worth a look.
