What type of antifreeze have you got in at present?
Posted: Fri Dec 11, 2009 12:26 pm
Hi all.
http://www.rrbew.co.uk/FeatureHtms/F-Antifreeze.htm
The above article on the Rolls Royce forum talks about the resent change over by manufactures of antifreeze from IAT to OAT. The latter may not be suitable for our older cars.
I have checked on my stocks and found that prior to 2007 I was using diluted Ethlene Glycol (Comma) and am now using OAT new 5 year antifreeze (Comma).
Not all the jacket water leaks I have experienced over the years are due to this change, but the MkII has been on OAT since 2007 and I have a persistent leak near the water pump and minor leaks on another engine I built in 2008.
In a nut shell a RR forum contributor had wet liner leaks into his sump that destroyed the bearings when he changed over from IAT to OAT antifreeze.
I have contacted Rosy Pugh of the FBHVC who is looking into it. I believe my cars are leaking due to this antifreeze, but I use hylomar to seal my gaskets which is an old fashioned sealant that hopefully is a defence against this POTENTIAL problem.
The article is worth a read.
