S-type vacuum operated heater valve.
jackois
Postby jackois » Tue Nov 27, 2012 11:52 pm
Just a note for anyone looking for a replacement for this item.
I have obtained & installed a valve from the States, originally for a Ford & opens when vacuum is applied. The water pipework is of the correct size but the vacuum pipe had to be swaged out using eletricians tape until a good seal was obtained. Obviously it wouldn't do on a car entered for concours events, but for everyday use, it does do the job. I'm certainly pleased with it as previously as tap type valve was fitted & had to be operated from under the bonnet.
vacuum valve.jpg (8.96KiB)Viewed 3869 times
It was bought via ebay from MR FOMOCO MOTORCRAFT store and is described as 'FORD VACUUM ACTUATED HEATER VALVE 18495 VACUUM OPENS 5/8" HOSE' Cost was around £16 including postage. The item took about two weeks to arrive.
Re: S-type vacuum operated heater valve.
Postby J44EAG » Tue Nov 27, 2012 11:59 pm
Is this item for the classic S-type rather than for the modern 1999-2007model?
I just query this as I have a question mark as to modern S-type application.
Rather confusing perhaps, but the classic S-type is served by the Mk2 Bulletin Board.
ecosselynx
Postby ecosselynx » Wed Nov 28, 2012 10:46 am
Hi Mike
Surely they have more in common with the Mk2 & 420 models than the new S-type!
bye-o
John H.
jackois
Postby jackois » Wed Nov 28, 2012 7:29 pm
Hi guys,
yes, this is classic sixties Jaguar S-type... and that's why I posted in the Mk2 board.
hope this helps.
Jacko
Postby J44EAG » Wed Nov 28, 2012 8:44 pm
Sorry. My mistake misreading the BB heading. Easily confused nowadays!
I`ll use me good eye next time.
sweller
Postby sweller » Thu Nov 29, 2012 7:41 am
Looks very useful as mine is dead (I think that's a common fault!)
Have you got a picture of it in-situ? Does it simply bolt up?
It does look rather shiny but I suppose a quick blow over with matt black paint will make it look a little less obvious under the bonnet.
Although turning off the heaters this time of the year isn't my first priority!
Simon
Brighton
Sussex
Martec
Postby Martec » Thu Nov 29, 2012 6:15 pm
Not sure if this is of any help to anyone, a couple of years ago a guy drove his new to him classic S type to the local club. It was too high at the rear and too low at the front and hissing nicely, I warned him that if he didn't get the vacuum leak fixed soon he could damage his engine as the vacuum take off is on the inlet manifold at the rear cylinder and a leak can make that cylinder run weak, overheat and seize.
A few weeks later he was recovered from the motorway with a seized engine. It cost a lot for his engine to be rebuilt.
