Front subframe/ suspension bushes
ianrushworth@lg
Postby ianrushworth@lg » Thu Jul 29, 2021 8:05 pm
I will shortly be re-buildimg the front suspension on my early 1960 Mk2 3.8. As well as Harvey Bailey stiffer springs and polybushes (Superpro) on all suspension bushes, I will replace the sub-frame mounts. I note there is a polybush option for the front mounts. Does anyone have experience of these, and if so is it too "harsh". I also note a 5 times difference on price for the rear items between "genuine Jaguar2 and repro on Barratts site. Are genuine worth the difference?
piman
Re: Front subframe/ suspension bushes
Postby piman » Fri Aug 06, 2021 10:36 am
Hello Ian,
coincidentally I have just bought the polyurethane front and the pattern rear from Barratts. I am working on the basis if the rear mountings have a shorter life I can buy the cheaper one again and still be ahead by a long way?
peterheywood52573
Postby peterheywood52573 » Sun Aug 08, 2021 9:30 pm
I was hoping there would be a PU option to the steering pivots
On the superpro website https://www.superproeurope.com/products ... cleid=7384 it does list a Draglink bush but they look too chunky to me.
Peter
Martec
Postby Martec » Tue Sep 07, 2021 6:07 pm
When I rebuilt our MkII I fitted polybush bushes to the wishbones and the anti-roll bar as the original bushes didn't last long. I later fitted the poly front subframe mountings that rattled my teeth on our concrete motorway. it is now tarmac so they have gone back in!
I have also fitted poly bushes to some in the rear springs plus the tie rod. It all feels good and reduces the maintenance.
I also have a set of what we thing are Harvey bailey front springs (check the wire thickness) and a front anti-roll bar from an S type or 420 with 1/2 a degree of negative camber.
PPV
Postby PPV » Fri Sep 10, 2021 5:25 pm
I have just had mine all my suspension refurbished by Bob Bate and he recommended using OEM components as others he had found far too harsh unless you are going racing! Pleased with the resultant ride.
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
