The distance between the outside of the rear wings at the centre of the axel is 1670mm give of take a knats ,
65 Stype , my earlier post stating my wings had been modified is WRONG , so ive got standard 20mm lips not returned into a U shape , my rear wheels are 6" with 205 tyres these remove easily . Russ
420 Rear Wheels
Re: 420 Rear Wheels
Russ, that's interesting. Just done a (very) rough measurement and it is closer to 1550. The height of the top of the wheel arch at the centre is 48.5cm on the right and 50cm on the left - difference could be tyre pressure. The lip on the inside of the wheel arch is about 3/4 of an inch. Something just does not add up to me because this car has been used regularly since rebuild and I just can't see someone driving a car when you cannot change a wheel if required. These wheels have been fitted since rebuild and I find it hard to accept that the shocks needed to be disconnected to accommodate this. Am I missing something really basic here? I will try and post a picture of the wheel arch later.
Re: 420 Rear Wheels
thats over 4" ? , r we talking about the same thing ? , i measured between 2 plumb Levels touching the body at the centre of the hub , Have u got wires K ? , if so , whats ur overall axel width ? . R
Re: 420 Rear Wheels
OK, Time for me to eat some humble pie.
Set the afternoon aside to do some in depth investigation & measurements. Put the rear of the car on axle stands at the jacking points to try and remove the rear wheels, make notes of where exactly it was catching the wheel arch, amount of spline left etc. Happy that is was secure on the axle stands I pulled/rotated/rocked the wheel on the spline and, yes, it came off! Ditto the other side. They went back on quite easily too. I had tried this before but obviously not hard enough. In my defence, the wire wheels on my MG come off quite easily and I had not expected this much effort would be required. I suspect the inner wheel arches are fitted a little too close in hence the (non) problem. I would not like to do this at the side of the road with only a vehicle jack but if I carry an axle stand in the boot I think I will manage should the need arise.
Thank you to all who took the time to show an interest and offer a solution. It would appear this is a largely self inflicted injury but I am a lot happier now I know I can get the wheels off when required. It also makes sense with what I know of the history of the car.
Every day is a school day!
Keith
Keith
Re: 420 Rear Wheels
Nice hear you have got somewhere with your problem, now you need to drive it on those lovely roads you have up there.
Best wishes,
Best wishes,
Re: 420 Rear Wheels
Hello Keith,
glad that it has worked out without any surgery. Perhaps your wheels and hubs need a clean and re grease?
