I have a 1967 Jaguar MK II 3.4, the front tyres are beginning to wear on the inside edges and before taking the car to the garage tohave the tracking adjusted I would like to be armed with the alignment data.
Can anyone tell me tracking information, i.e. the degrees of toe in/toe out?
Also the steering is very heavy which I understand is not unusual apart from converting to power steering is there anything that can be done to make it lighter?
Thanks.
Wheel Alignment Data
Hello Phil,
I don't have my manual to hand now, but from memory between 1\16" to 1\8" toe in.
The first thing is to ensure your tyre pressures are correct, but 'heavy' is very subjective particularly if you usually drive a car with light steering.
Mine is fairly heavy at rest (as is my Triumph 2000) but once moving is very light and the last thing I would want is power steering as that would be too light for me. As I say very subjective.
Hi Phil
My manual gives the toe-in as parallel to 1/16" toe-in. As Alec says, correct tyre pressure is important to reduce the heaviness of the steering, but these cars are heavy to steer at low speeds. I've fitted power steering to mine and find it a lot nicer to drive around town, but opinions do tend to polarise on this issue.
Best wishes, David
Best wishes, David
I had a similar problem on my Daimler V8. It turned out to be due to poorly aligned REAR WHEELS. Some clown who had ownwd the vehicle before me had welded the panhard rod up after a failure and the result was that the wheels were well out of alignment!! Also check the run out of your front wheels - if the locking wheel nut has been set too loose, then the wheels can shimmy and cause unusual wear patterns. Alec Gurney.
Re: Wheel Alignment Data
I have a 1963 Daimler V8 2.5 and are in the process of wheel alignment after loads of other restoration tasks. The workshop manual warns NOT to use the inner tie rod to adjust the toe-in but the outer tierods; mine however are solid steel with a ball-joint at each end. So where and how do I adjust???
Thanks,
Fred
Thanks,
Fred
Hi Fred
Does your car have power steering? If not, you can set the toe-in by adjusting the centre tie-rod. On cars with PAS the centre tie-rod should be set to a length of 41.7 mm between centres and the toe-in adjusted with the outer tie-rods after centering the steering box. If you do have PAS and solid outer tie-rods, it is likely that you will need to change these for adjustable ones.
Best wishes, David
Best wishes, David
Thanks David,
You're spot on and I'm stupid.
I've actually read the powersteering part where I do not have PS.
Thanks a mill,
Fred
Thanks a mill,
Fred
