Lower Steering End Yolk
470HW
Postby 470HW » Fri Dec 18, 2015 11:46 am
Help!!! I've just broken the end yolk of the lower steering column. The car is MK2 3.8 chassis number 2006480.
When I took the part off it was extremely tight on the spline. Trying to refit it proved impossible without widening the hole which I did by tapping a chisel into the split. Although this worked for the top journal the bottom journal split.
From the parts manual the part is 8046 End Yoke (plate 80 - 9). Trouble is nobody I can find has this part in stock.
Does anybody therefore, know of anybody that can supply this part. If the worst came to the worst I could weld it but I'm extremely reluctant to do so.
Any help or advice greatly appreciated.
Ian
Jaguar MKII 3.8 manual. Triumph Vitesse 2.0l MK2. Triumph Bonneville 650 chop.
Martec
Re: Lower Steering End Yolk
Postby Martec » Fri Dec 18, 2015 4:54 pm
You could try ringing Ken Jenkins he has a lot of second hand stock.
I'll have a look in my garage loft tomorrow (back playing up at present) as I replaced all that lot with links from an XJ6 many years ago. There might be something left up there.
470HW
Postby 470HW » Mon Dec 21, 2015 8:14 am
Hi Brian
Thanks very much for the response. I think I've managed to track one down. Can't be absolutely sure it's the right part so won't know until it gets here. Many thanks for your help though and I hope your back gets better.
Ian
