The steering wheel on the 1963 MK2 I’m restoring is different to the one described in the Haynes manual an on e-bay. Are there 2 different types of the black plastic wheel and are they interchangeable on the column splines?
My wheel is plastic covered and the plastic has split up the boss across the back of the arm and onto the rim. Is this a common problem?
Finally, can anyone suggest where I can get a replacement?
Russell
Steering wheel types
Re: Steering wheel types
Hi Russell, if you check in on e bay and in the search box, type in Jaguar Mk2, then click on parts, you will find that there are hundreds of parts for sale and sometimes Mk2 steering wheels come up for sale. Also you could put a wanted advert in the JEC magazine, as I'm sure someone out there will have a spare one in their garage. Patrick
