Just wondering if anyone has any experience or knows anyone who has had experience with this as i`m interested in the conversion for my 420.A few kits are on fleabay and it seems like an easy conversion and cheaper and less intrusive than LPG ,and apparently improves performance.Is it too good to be true.
On another note i am going to fit an engine bay fire extinguisher system using an ordinary car fire extinguisher inside the car connected to plastic pipe(like that used on trucks for the air brake systems) running around the edge of the engine bay with holes in it at strategic points.Similar to the systems available for the engine bays on VW campers but not constsantly under pressure and therefore cheaper.
Hydrogen assisted fueling
I have no experience of the hydrogen fuelling kits and I can't find one on eBay, but I tend to take the view that if it isn't offered by a mainstream car manufacturer and it seems too good to be true then it probably is too good to be true!
Incidentally, I'm seriously considering biting the bullet for my S type and converting to LPG so would be interested in others' experiences
Why would you want a fire extinguisher kit? Unless you're racing it or intend to crash I can't see the point.
I've had three bay window campers and their predilection for spontaneous combustion was down to their reliability - owners could get away with minimum maintenance and many tried to.
The most effective (and cheapest) way of preparing for VW fires was to change the fuel hoses from time to time as they deteriorated with age and were the cause of the brew ups.
The HHO fuel assisters are widely publisized in the states and as long as the kits are well made with all stainless steel fittings then they are safe and reliable and are proving very popular.
As for the fire extinguisher, i know of a few people that have had engine bay fires in classic cars and wheather its electrical or fuel related then for a small outlay it has to be worth using,besides have you ever seen a 4.2 spit back through the carbs,very scary.Even modern cars can set on fire and these days even more seem to be doing just that(maybe down to more complex and a greater amount of wiring)so even if i don`t use it ,it has to be worth it for piece of mind when i`m carrying my family around.I`m also fitting such an extinguisher to the family PT Cruiser,again a small outlay for piece of mind where the family is concerned.
I may seem a little paranoid about vehicle fires but when i was in my late teens i was a voluntary firefighter in a small village and was called to such a fire on the bypass where a ford capri had burst into flames due to a fuel leak and the driver perished before we could get to him.The driver was a friend and put an end to my ability to handle the firefighting.A shame as i had just completed my training to become a career firefighter and was waiting a posting.
With the reference to LPG, I rebuilt my 3.8 MkII from a wreck, then found I couldn't afford to take it out of the garage.
I bought and fitted an LPG kit from a local supplier in May 02, this system came from 'Tinley Tech'. I have been very pleased with it and enjoy filling up at my local Shell garage for £14-15.
I have kept the two fuel systems separately so problems with one doesn't compromise the other, but have not had any problems. In the winter I have to start it on petrol and change over to gas, but over the last few days have been starting it on gas.
The availability is the main problem, I'm in Humberside and gas is relatively easy to get, the further north you go the harder to find, particularly Scotland. The south of England and especially Europe is very good.
One recuring problem has been having to replace plugs approx every 2000 miles (spare set always carried) as it starts to miss and spit back on low speed acceleration. I think we now have the solution, a switchable ignition ECU so that there are two maps, one for gas and one for petrol.
A friend has converted a MkII Capri to 3ltr V6 ecotec engine with his own EFI ECU and has now converted it to run on LPG. He found that at 2000rpm it needed 14degrees extra advance to really pull well.
Needless to say I am in the process of converting mine to ignition ECU (2 ignition systems and 2 fuel systems) with another of his ECU's (CANEMS), one already runs my EFI of a 'B' series (BL) engine.
Martek,that`s some interesting results you have there,i was considering fitting an LPG kit myself from Tinley tek as it wasn`t too expensive or difficult but i`m fascinated by the idea of running my car on water,well a by product at least and the fact that the government will get nothing extra off me.
If you google hho gas,and view the many films you will understand the principals much better .The cutter to replace oxy acet cutting is very impressive.
