Fuel being drawn from the 'wrong tank'
geoffincornwall
Postby geoffincornwall » Fri Sep 21, 2018 1:23 pm
While using fuel from the RH tank with LH Pump OFF fuel was drawn from the LH tank to the extent that when the RH tank was empty the LH tank was three-quarters full. The journey started with both tanks full. Is this normal? What has 'failed' if not?
G
