Throttle linkage adjustment
ChrisDixon
Postby ChrisDixon » Thu Jul 27, 2017 5:51 pm
I serviced the carbs and despite carefully assembling the linkage and the connectors between the 2 SU HD6 carbs (on my 3.8S) the throttle pedal remains quite stiff. It all seems free when disconnected so I wonder if the pedal linkage isn't set up correctly, perhaps not giving the right leverage at the two points, the pedal pivot and carb spindle pivot. Is there a specific setup for these?
heath_matthew277
Re: Throttle linkage adjustment
Postby heath_matthew277 » Tue Oct 20, 2020 10:17 pm
Hi Chris,sorry for jumping on the post but did you manage to sort this?? I’m encountering the same problem after I’ve just serviced my HD6 carbs. Cheers Matty
piman
Postby piman » Wed Oct 21, 2020 9:34 am
Hello Matty,
Yes there si a specific adjustment for the linkage betwwen the support bar attached to the front of carburettors and the throttle spindle.The acelerator linkages attaches to this and the attachment point should be 1/16" lower than the centreline of this linkage. I.e. the linkage is not quite straight but is a very shallow angle downward. The throttle lever attached to the carburettor throttle spindles should be vertical also.
