I rebuild carbs for enthusiasts of the Honda CBX 1000 six that has six carbs that are CV and 3 circuit so it shouldn't be too challenging.
Will keep you posted.
Goss
Yes, 10,000 miles and 18 years in October in which time it has not moved so I'm not surprised.I'm very surprised to read that heat had to be used to release the idle screw on a carb that was "rebuilt 10,000 miles ago". Unless you know and can trust the quality of the "rebuild" work it might be as well to discount the earlier rebuild and start from scratch!
Robbie
Hello Chris,I have experienced a similar issue with the idle decreasing to the point where it would sometimes stall when the clutch was depressed, although this has improved significantly since I serviced the carbs and fiddled with the pedal linkage. Not a full rebuild just cleaned them up, fitted new gaskets and re-tuned them, using the basic settings and the piston lift pin. The front carb tends to run richer than the rear, maybe due to slight AED leakage. Hot starting continues to be hit and miss though.
If the engine idles ok once it has been started, then it isn't necessarily the idle mixture? I put an octance booster in regular unleaded fuel, others advocate Shell Ultimate with or without an additive. I did observe that I had to adjust the screws out some way from the basic settings, and the rear carb ran leaner. Some of this could be due to wear in the carbs (but this should have less impact at idle because the throttle discs are closed and take up some of the slack in the spindles) and slight AED leakage. Also hot starting technique, do you try at first with the throttles closed or press the accelerator part way before attempting to start? You tend to learn what works for your car, but again there can be a difference between a hot start after a couple of minutes to one where the engine has cooled a little. I set my car up without any tuning aids but I have since acquired a Colortune and Carbalancer and I look forward to seeing whether they help with tuning any more than the piston lift technique!I know from the Honda carbs that I rebuild that they are no longer set up to original factory settings due to the less potent modern fuels (addition of Ethanol) which means they run too lean on tick over (1.5 turns out now 2.5 turns). This circuit does supply fuel constantly throughout the rev range so I am looking to set up using a Gunson's Colourtune which was used when first set up. I guess the adjustment of the idle mixture when the engine is hot would solve the hot start problem?
