Fuel pump mounting bushes
david.b
Postby david.b » Tue Feb 18, 2020 12:40 pm
Morning, can anyone point me in the right direction please? The mounting brackets sit on rubber bushes with encapsulated threads top and bottom. Could very well be me but can’t find them anywhere.
Thanks in advance.
piman
Re: Fuel pump mounting bushes
Postby piman » Tue Feb 18, 2020 1:28 pm
Hello David,
assuming a MK 2, part numbers are :- Stud C801, Gromett C10126, Distance tube C20323, Nut C8150/33,Washer FW205/T and Washer, Special on Studs, BD541/5.
A quick look on the SNG Barrat website gave only the grommett being available. You might like to try Classic Motor Cars in Bridgnorth and see what they use these days, I've no doubt they will be able to supply a suitable alternative (Presumably one piece rubber bobbins with studs in the correct thread?
