Rear bumper rubber 1962 MK2
weddingjags
Postby weddingjags » Wed Mar 05, 2014 11:03 am
Does anyone know if the rubber strip can be replaced with out removing the rear bumper? It looks like there are clips holding it in place and I don't want to remove the old one if I have a bigger job on my hands.
PPV
Re: Rear bumper rubber 1962 MK2
Postby PPV » Wed Mar 05, 2014 12:22 pm
I found it an easy job to remove bumber to replace the strips. Jus a bit heavy so got the wife to hold it in place whilst undoing nuts etc! I did the overrider ones also as they had deteriorated also.
Regards.
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
weddingjags
Postby weddingjags » Thu Mar 06, 2014 8:21 am
Thanks Paul, bumper off then.
Martec
Postby Martec » Thu Mar 06, 2014 11:43 am
It sounds as though I have mine incorrectly fitted as the rubber just fits in easily and the end clips just rest partially on and to the bumper?? I took the rubber and chrome end clips off before removing the rear bumper for re-chroming. Am I talking about the same thing as you, the rubber fillet that sits between the bumper and the body?
PPV
Postby PPV » Thu Mar 06, 2014 2:00 pm
Brian, mine was a very tight fit and the original started to break up trying to get it out. I suppose you could try doing it like you do a windscreen rubber but taking the bumber off also allowed me to clean the back of it and then protect it for the future.
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
