Rear bracket for spat
smiffy
Postby smiffy » Sat Dec 31, 2011 10:49 am
Does anyone have a photo or drawing of the small bracket that bolts to the rear of the wheelarch and provides the mounting point for the pin on the rear of the wheelarch spat? Both of mine have rusted away, one completely, so I only have a vague idea of what they should look like. I guess that I'll have to fabricate them, as I can't find them in the Robey catalogue.
Best wishes, David
cstorey
Re: Rear bracket for spat
Postby cstorey » Sun Feb 05, 2012 8:44 pm
No photo, but they are basically a near right angle bracket with a dished hole in, of sufficient diameter to accommodate the circular spigot which is on the rear of the spat . You will be able to fabricate one in a few minutes, but it will be best to make a template in very thin metal first , e.g. a cut up soup can , so as to position the hole accurately
ecosselynx
Postby ecosselynx » Sun Feb 05, 2012 11:00 pm
Hi David
If no better/quicker offer turns up I'll take one of mine off and measure photograph for you, unfortunately at work right now, so if you cn wait 10/14 days I can get for you. Hopefully one of the lads will get you the photo/measurements before then.
bye-o
John H.
smiffy
Postby smiffy » Tue Feb 07, 2012 11:12 pm
Good evening John
Thanks for the offer, which I'll gratefully accept if you have the time to do it. No great rush, as the car is up on my hoist for the next batch of welding.
Best wishes, David
ecosselynx
Postby ecosselynx » Wed Feb 08, 2012 12:10 am
Hi David
Should you not get the information earlier, then once I'm home I'll take off a spat and measure/photograph the bracket for you.
bye-o
John H.
