Front grill
jwment
Front grill
Postby jwment » Wed Jun 23, 2010 9:47 pm
I've read up on how to remove the radiator grill in several publications now, and they all sound simple .... BUT ...
They seem to indicate that there is a removable panel that is released by removing two screws, then you can get an arm in to remove the nuts holding the grill in place.
No one gives a picture as to the location of this 'Hatch' or it's securing screws though, and look as I might, I ain't found it yet.
All I actually need to do is remove an RAC badge, and replace it with an AA badge, but both are fitted with screws from behind.
When I get the grill off, I'm also considering experimenting with changing the bars to a mesh. Any one seen this done before, or have any opinions as to 'Why not' ?
Johnny
PJF
Postby PJF » Thu Jun 24, 2010 3:23 pm
The hatch forms part of the radiator cowl, in front of the radiator, at the bottom.
From memory, the screws are about 10cm either side of the car's centre line.
If the car has a good thickness of underseal then both the hatch and screws can be difficult to see.
As for the mesh, I've never heard of this being done and I think there may be a couple of reasons why.
I would be surprised if there is much support for it on aesthetic grounds, but more importantly, you are a very lucky man if your Mk2 does not get hot at some time and replacing open vanes with a mesh will severely impede air flow. I'd lay money that it will cause over heating problems, even if you have none now.
jwment
Postby jwment » Thu Jun 24, 2010 10:37 pm
Ta for that PJF.
At least you've confirmed that I should be looking at the bottom of the cowl. Can't see clearly through the grill as there's a (non standard) electric fan mounted in there that is independently switched from the dash, to counter overheating in traffic.
The car is too low to get my head under the number plate to look from below, and by touch, all I can feel is underseal. Guess it will have to wait until I've resolved the jacking problem.
The jack supplied with the car doesn't fit in the sockets, and the front cross member is too low to get my trolly jack under. The car is not currently movable, and chocked on quite a steep a slope, so I guess this is a 'wait out' scenario for now. :(
I should have found a shed/garage/barn to keep it in before I bought it, but as soon as the previous owner opened the garage door ... it was love at first sight... I just knew it was coming home with me. So now it has to live on a steep driveway until I can find a level floor to start work on it. Regretably my health hasn't been so good lately, so progress has been pretty non-existant since it arrived.
As to the mesh, I do appreciate that restricting the air intake is not a good idea, but it was a very open wire mesh I was thinking of, not the modern perforated plate type. Possibly coupled with louvres in the bonnet, but I am going off that idea. We get a lot of rain in Wales.
Whilst on the subject of incoming air ... purely for a neater look, I'm thinking of replacing the large (tatty) tubular air filter with two chrome pancakes. I've noticed quit a few cars in the magazines are fitted with them. Any reason not to? I have sussed where to divert the oil mist vent pipe. It's a late 3.8 engine with twin SUs, probably of 'S' type origin, but it looks like a 240 air filter to me. See 'Conwy' in gallery for piccies.
Any thoughts of maintaining any classic 'origionallity' were thrown out a couple of owners back. This is very much a fun car, user hack, not a Concours show car. :wink:
Johnny
jwment
Postby jwment » Sat Jun 26, 2010 5:03 pm
Hmmm? I've found the screws to undo the hatch...but the Philips headed screw heads are inside the cowl, as is the hatch plate. :?
It's gonna require a 24" long screwdriver to get at them, and needless to say, the Fan frame is well in the way. Even with the hatch off, it's gonna be awkward getting an arm past the fan mounting.
I can only assume the last owner put the hatch on ... attatched the grill from the inside ... then attached the fan to the radiator ... and finally fitted the radiator into the car. :roll:
Methinks the RAC badge is gonna stay where it is for some time yet !!! :idea:
Johnny.
Postby J44EAG » Sat Jun 26, 2010 7:13 pm
Hello Johnny,
My thoughts as follows.
Open mesh grill in wire stainless mesh form will be unlikely to cause cooling issues. Infact if one could be bothered to work out the amount of restriction caused by the wires per square foot or cm or inch etc, you would probably find there was an increased airflow to the radiator rather than a restriction when compared to your standard grill cross sectional area.
If you go the mesh route, I`m sure Geoff Adams at Adamesh would be able to supply a suitable sized piece for you. He is a great guy to deal with.
Airfilters. I remember having a set of chrome units on sports cars in the seventies. Filtration was negligable with only an old piece of oil covered wire "wool" to act as the filter. A total waste of time in my opinion. They filtered nothing and didn`t improve performance. One also ran the risk of having the engine gobble the filter internals!
Now we have a good choice in after market filtration systems. The most popular are oiled cotton meshed units from manufacturers such as K&N, Green Filter and Pipercross. These will allow a greater volume of air to be drawn into the engine without upsetting mixture setting or causing other problems. It is quite possible to find them available to fit your existing filter box as direct replacement items. They are washable at service time and life expectancy is almost indefinate given careful handling. A head and shoulders above the cheapo chome pancakes that we used to misguidedly put on our cars years ago. I`ve used such filters for years and would never go back to a paper eliment or old style pancake unit.
I`ve found the cheapest supplier to be Motorsportworld on the net. They are a UK based family company and are very helpful. Well worth a look on their site even for consumables for older cars.
Trust this is helpful.
Mike Kennedy S-type Co-ordinator.
ManxNeil
Postby ManxNeil » Mon Jun 28, 2010 11:31 am
Hi, Johnny,
Even once I'd located the hatch, cleared all the underseal and removed it, I found the hatch aperture didn't provide enough access (too small and and too low down) to get to the mounts for the radiator grill. It was less hassle for me to remove the radiator itself to gain access to and remove the grill.
Cheers,
Neil
Mk2 3.8; X350 4.2SE
jwment
Postby jwment » Mon Jun 28, 2010 12:31 pm
Thanks for that Mike. :D
The pancake filters I have did indeed come from MotorSport World, but I haven't tried to fit them yet.
Performance issues aren't a great concern. Apart from an occasional motorway trip to pick up the grandchildren, this old bus mainly just cruises around the North Wales lanes. At least it does when it's running.
And cheers to you Neil .... :(
There's just gotta be an easier way to get the grill off than removing the radiator ???? There's only one fixing either side that seem loose enough to maybe lever them out. The lower ones are missing, but it is firmly attached at top and bottom centres.
Johnny
ecosselynx
Postby ecosselynx » Tue Jun 29, 2010 9:12 am
I can't believe you find it so difficult! I have placed an oil cooler in front of my radiator. I can undo the two nuts of the cover, remove the two mounting nuts for the oil cooler, move the cooler back, lift the cover out and get up to lossen the grill nuts (and there's a Kenlow in front of the radiator. I'll give it to you that its not easy, but I don't intend doing to often.
regards
John H.
ManxNeil
Postby ManxNeil » Tue Jun 29, 2010 9:49 am
I'm built like a (dilapidated) brick outhouse - with arms to match - and I have fingers like pork sausages, so maybe that explains my difficulty!
Neil
Mk2 3.8; X350 4.2SE
jwment
Postby jwment » Wed Jun 30, 2010 12:36 am
My basic problem is that the hatch cover has been put on the inside, and appears to be secured by two large crosshead screws with the heads inside the cowl. If I use a screwdriver with a two foot blade I might be able to shift them, but I haven't got a screwdriver that long. Nor could I buy one locally. I'll have to try on the web.
Johnny.
jwment
Postby jwment » Sun Jul 11, 2010 4:52 pm
OK ... by fitting a few 1/4" socket set extentions together (taped up to stop it all falling apart), I now have an 18" philips screwdriver.
I can now reach the screws by threading this down from the top of the grill and through the fan support frame.
i've tried seven different cross head drivers, but can I get enough purchase on the screws to undo them? .... Nope. They just will not turn. Can anyone please explain to me again why cross head screws were invented?
So ... it looks like it's back to plan B ... Take the whole damn Rad out !!
Yeah, like that's gonna happen any time soon.
Johnny.
