420 transmission conversion
JamesWheildon
Postby JamesWheildon » Wed Dec 11, 2013 9:23 pm
Has anyone converted a 420 from auto to manual? What boxes can be used? I really want to get away from 4000 rpm at 70 mph.
oldtimer
Re: 420 transmission conversion
Postby oldtimer » Wed Dec 11, 2013 10:03 pm
Wow,
That seems a bit high, found manual box ratios, nothing for auto
Sure somebody will come up with what it should be.
Save changing the box
ecosselynx
Postby ecosselynx » Wed Dec 11, 2013 11:44 pm
Hi James
4k RPM sounds a bit on the high side, although not sure what the gear box and diff ratio's you have. Would have expected it to be around 3200 RPM at 70 MPH (don't have any books with me at the moment to check.
You can always look at changing the diff for another with a higher ratio, should it be lower than standard.
bye-o
John H.
