Page 1 of 2
Clutch servo
Posted: Sat Dec 15, 2018 2:44 pm
by 4jagsjohn
Hi everyone. I have finished me ground up rebuild of my Mk2. I want to fit a clutch servo to reduce the load on the old leg. (My trusty E type is auto ) I was going to change the Mk2 to auto but entailed to greater amount of work. As I wish to use this car a lot in the future can anyone advise as to where to locate the servo as very little room in engine compartment as you will know. I have fitted power steering so no room as such on the exhaust side. I daresay under a wheel arch is a thought but not good for weather intrusion. Any advice would be much appreciated. John
Re: Clutch servo
Posted: Mon Dec 17, 2018 9:36 am
by 340jag
You could put the battery in the boot , free up some space !
Re: Clutch servo
Posted: Mon Dec 17, 2018 11:26 pm
by 4jagsjohn
Good point. I nearly did when I did my rebuild but changed my mind. If can't think of anything else may well go down that road. Cheers.
Re: Clutch servo
Posted: Fri Jan 25, 2019 9:10 pm
by Martec
I fitted a servo for the clutch under the front wing, waxed it and put a cover over the air valve, it has served me well for quite a few years,
I used the small servo that is sold for mini's.
Re: Clutch servo
Posted: Sun Jan 27, 2019 11:30 pm
by 4jagsjohn
Thanks your reply Brian. I will go down that route as it is the best option I think.
Re: Clutch servo
Posted: Mon Jan 28, 2019 12:21 pm
by B87UL
John
I was going to fit a clutch servo and worked out, as Brian has done, that taking everything into consideration the best location would be under the right front wing. My intension was to fit a remote breather by utilising an old type Briggs Strattan lawn mower crankcase breather. In fact I actually purchased a small servo but so far it is still on the workshop shelf.
Instead I decided to fit a larger bore clutch master cylinder from SNG Barratt. I have fitted a temporary back stop arrangement on the slave cylinder to allow positive clutch bearing clearance, this stop also allows me to adjust the clutch pedal take up position to my personal liking. This has improved the situation and is satisfactory for me at the moment.
I would be interested if Brian could say if he can obtain a satisfactory clutch take up position near the bottom end of the clutch pedal position. If you do have issues with a heavy clutch operation I find the actual take up position can make all the difference.
Should you do go down the route of fitting the battery in the boot it is worthwhile considering coupling up in the boot via an Anderson plug and socket. I have a 1965 S type with batteries in both locations, original and the boot, but I would not fit one in the boot unless I absolutely had to do so.
Re: Clutch servo
Posted: Thu Mar 14, 2019 4:36 pm
by 4jagsjohn
Sorry my late reply thanks your advise. I shall probably go with the mini servo option shortly. Putting up with heavy clutch at present. Did the larger bore slave you fitted make the clutch pedal lighter by a good amount. Thanks for your advise. John.
Re: Clutch servo
Posted: Thu Mar 14, 2019 8:32 pm
by B87UL
John
I used a larger master cylinder, not a larger slave cylinder. I found it improved matters so that the clutch effort was acceptable for me. You need to be aware that a larger master cylinder displaces more fluid on each stroke and the clutch pick up point will alter. However you might well find that situation occurs with a servo in any event.
Having said that, I found the original clutch pick up point was not acceptable to me and needed a back stop fitting to the slave cylinder and the fitting of the larger bore master cylinder. Now the slave cylinder allows adjustment so that I can set the clutch to pick up just as I ease my foot from the floor. Although I am past my four score years and ten, I have driven the car on fairly long trips to Eire and France, with no problem to me.
Norman
Re: Clutch servo
Posted: Sun Mar 17, 2019 3:21 pm
by Martec
I've just replaced the clutch fluid and started it up, the clutch bite it close to the top of the peddle.
I moved the battery from the front to the boot on another car and found there was a big volt drop even with a heavy cable front to back, so I fitted a very large battery and ran a separate cable for the radio that kept losing its tuning. What I should have done was to run another big cable to feed the new high torque starter.
Re: Clutch servo
Posted: Mon Mar 18, 2019 12:31 pm
by B87UL
Is that the first time you have experienced the clutch bite at the top of the pedal stroke, or was it like that before you carried out a recent fluid change?
Further, are you looking to change the bite point, or are you accepting that situation?
Some years ago, as a young automotive engineer, I had to cure a clutch throw out problem on a large number of trucks. They had a similar, if not identical layout, to the Jaguar with hydrostatic cylinders. In the early to mid-60’s a number of manufacturers tried, and then had to modify the clutch hydraulic system, looking at the number of their cylinder changes, Jaguar were no exception.
On both truck and car we experienced slave cylinders being pushed back under motorway driving conditions, so that there was no clutch action on the first pedal stroke. The other, not so common, problem was “hydraulic compounding”, and I can see the possibilities with the Jaguar. This normally occurred when the driver could not select 1st or Reverse; they would then operate the clutch pedal two or three times. At that point the clutch would over stroke if the pedal had been pumped fast, the action really replicating the movement and self-adjustment of disc pads. Sometimes the compounding would cause breakages to the clutch forks or front gearbox front plates.
Basically I ran a fleet campaign to convert them all with cylinder return springs and a cylinder back stop arrangement. This had a number of advantageous; it allowed the cylinder to withdraw sufficiently, it provided a method of setting the clutch pedal bite position, and it prevented clutch over stroking in practice.
It seems to me that you have not come up against any of these problems even with a clutch servo fitted, with the exception that the clutch pedal bite position is high. Am I correct with this statement?
I am particularly interested because years ago I cannot remember modifying any Jaguar’s, probably because they were usually Automatics, I have obviously modified my own S Type, but am interested in other owner's experiences, particularly with a servo.
As an aside, I see you have a 3.8 ltr equipped for LPG, interesting in 1979 I had some 60 cars running on Propane with our own bulk tanks, about 10 of those were 4.2 Daimlers. Just don't try fitting LPG to 1970 / 1980 ish Cortinas
Correction….. my four score years, should read three score years
Re: Clutch servo
Posted: Mon Mar 18, 2019 5:47 pm
by Martec
I have 4 score years and 11!!??
The car was run on LPG but an old LP suction system infront of the carbs, but the repairs cost more than the fuel cost savings, much nicer to drive now back on petrol.
I believe the bite point has always been near the top and have no wish to adjust it. When I rebuilt the car and engine I replaced the short slave cylinder with the only one available, the later long one. I also fitted the spring from the short one and had difficulty in clearing the clutch and crunching gears. I was advised to take the spring off and it has been fine since.
I spent 32 years fixing up clapped out boats/ships!
Re: Clutch servo
Posted: Thu Mar 21, 2019 7:00 pm
by Martec
I thought I would give you an update on some knowledge I just gained from Ken Jenkins regarding my own clutch, it may help others.
I rebuilt my car from a seized rotten original wreck, it had an original 3.8 with moss box and 10" coil sprung clutch with the short clutch slave cylinder.
I returned the car to the road in 2000, but soon replaced the knackered moss box with the later full synchromesh and overdrive box, I had a new 10" coil clutch and the later long slave cylinder as it was the only one made at the time.
The other day after a few nagging doubts I jacked the car up again and checked the distance between the fork lever and pushrod with the pin removed, what should have been 3/4" was now 1 1/4", so I reset this to the correct 3/4". With the clutch peddle fully depressed the clutch fork lever is still clear of the back of the bell-housing slot, and the bite point is still near the top.
I spoke to Ken just now who was also concerned that the gap had increased (wear to the graphite release bearing) rather than a reduction in the gap (indicating clutch plate wear).
He said that although DOT4 fluid was OK for Brakes, Dot 3 was better for the clutch hydraulics as it lubricated better, also the clutch flexible pipe should be replaced every 5 years as it may be de-laminating and stopping the clutch from unloading fully.
Also that with the spring clutch I should revert to the short slave cylinder and external spring (if I can find it?) as the later long slave cylinder is really for the diaphragm (9 1/2") clutch.
So as I have always regretted ignoring Ken's advice I need to replace the flexy hose, DOT4 and the slave cylinder. That will hopefully give me another 50,000 miles over 19 years and remove the necessity of engine out to replace the clutch. Also the cost of an electric cable hoist to replace my very heavy chain blocks.
This I hope can help someone else.
Re: Clutch servo
Posted: Sat Mar 30, 2019 7:16 pm
by Martec
Hi B87Ul,
I now understand what you were referring to with the adjustment of the push rod on the clutch slave cylinder.
I finally received and fitted the new SS braded top hose, early short clutch cylinder and external spring, but not before using my boroscope in the bell housing and found there is very little graphite above the CI housing. So the whole lot has to come out to replace the clutch and release bearing.
As I need to move the car to another garage I filled and bled the new slave cylinder and using the clutch bite point I lengthened the push rod to lift the bite point off the floor, not very successfully as I can see the spring inside the cylinder fighting the external spring.
It looks as though the height of the bite point may well be an indication of the wear of the clutch and graphite thrust bearing. The self adjusting hydrostatic cylinder is a much better arrangement, at 50,000 miles life
Now I have to prepare to drop the engine out of the car!
Re: Clutch servo
Posted: Mon Apr 01, 2019 12:56 pm
by B87UL
Some more info……
I don’t quite understand your comment ….“as I can see the spring inside the cylinder fighting the external spring”………
However a few points, based on my professional and amateur experience as an automotive engineer /manager in different worldwide locations.
Using a hydrostatic slave cylinder with a carbon clutch release bearing is fatal as manufactures have found out since the mid 60’s. This is now fairly well known in manufacturing circles, except by some repairers and indeed owners, and ball thrust bearings are now universally used. Consider for a moment why Jaguar found it necessary to modify or change the slave cylinders?
If a hydrostatic cylinder is used, a ball thrust release bearing, not a carbon is mandatory. So, when you have carbon and hydrostatic operation it is necessary to modify the layout to avoid heavy release bearing wear. It seems that you have experienced this exceptional wear, BUT if your carbon is above the carbon bearing housing face and you modify the throw out action with a spring and backstop, you may yet attain some thousands of miles of use. In any event you would be scrapping the release bearing carbon and the clutch, so why not run it for a while, after modifying?
To avoid some of this heavy wear the easiest way is to fit a return spring and back stop so that the return spring pulls back the slave cylinder piston until it contacts the backstop and the release carbon bearing is clear of the clutch. This clutch clearance needs setting at about 0.125 inch clear at the release bearing to clutch face, even more if you can. All you need is for the clutch to clear when the pedal is just off the floor, that way you will not over stroke or stress the clutch.
On no account do you want the clutch bite at the top of the pedal…….such a position is telling you the release action is right on the point of starting disengaging. This situation is common to a hydrostatic design as the cylinder is forcing the release bearing into contact with the clutch even before the forces I mention below are coming into play. So your carbon is (has been) presently running in contact all the time particularly under actual running conditions.
Consider the following problems, all of which are reducing your static clutch clearance and causing excessive carbon bearing wear. You might see why your carbon release bearing is wearing prematurely and why if you have no return spring or backstop arrangement you are going to repeat history.
(a) The clutch is subject to tremendous centrifugal force, this tends to force the throw out linkages rearwards and reduce clearance between the release bearing and clutch.
(b) The gearbox primary shaft bearings have fairly large clearances and under load tend to steer the clutch pack into a wobble, this causes a kick back of the clutch bearing release face. The crankshaft assembly complete with clutch does not run square in the main bearings and main bearing clearances do not help our problem. Once again we have forces attempting to reduce our clutch clearance.
(c). The flywheel design of engines of our era does not help the situation and they cause tremendous wobble at the outer rims with a minimum of 0.020 inch movement and much, much more on certain types. This movement is nothing to do with a flywheel being bent or warped, but is caused by the flywheel design.
The engineers who found this running phenomenon on the post war six cylinders worked for R-R, they also found that a crankshaft elongates when the engine runs at speed under load. If you examine different flywheels you will find some reduced drastically in thickness where they bolt to the crankshaft, a finding of R-R engineering to counteract flywheel movement and passed on via their many engineering contracts with other manufacturers. I did not work directly for R-R, but I have worked in many countries on these R-R six cylinder engines and many of the Jaguar issues follow those of R-R even the clutch issues.
If the clutch is not slipping and otherwise performs well I would modify the release operation and run the car a while. From what I gather you now (latest) have a return spring fitted to the slave cylinder, but you still need a stop arrangement to control the bite point.
Hope you don’t have to remove the engine, as one gets older that really becomes a chore even when all the right tackle is available.
Re: Clutch servo
Posted: Sun Apr 14, 2019 8:55 pm
by Martec
Hi B87UL,
There is a tremendous amount of information there and I will need to read it several times.
My comment about springs fighting each other refers to the spring inside the slave cylinder pushing the rod out whilst the external spring is trying to pull it back it (maybe the aftermarket spring is not strong enough)??
I assumed the backstop was the the adjustment of the push rod so the the piston was against the back of the cylinder??
The new original clutch slave cylinder is working OK, no noise yet of metal on metal and feels odd with the bite point being so low.
I've decided that as I can't see any carbon/graphite I don't have much milage left so tomorrow I start removing the engine, I now have two wooden beams bolted together and an electric wire hoist to do the lifting, wish me luck.
PS I cocked up my age as well 71.
