Cylinder head colours
jspicer6
Postby jspicer6 » Sun Sep 23, 2012 2:28 pm
Hi there,
Can anyone tell me the correct colour for '66 3.8 S type head and where to buy from? Also which paint should I use for the block?
Regards Jason
piman
Re: Cylinder head colours
Postby piman » Sun Sep 23, 2012 3:57 pm
Hello Jason,
the cylinder head should be blue, I suggest trying one or two of the marque specialist spares suppliers? They could possibly also supply a suitable block paint. I've used smooth Hammeriote in the past although it is not the paint it used to be.
mark32
Postby mark32 » Fri Oct 05, 2012 4:55 pm
Hi there
On my one I used engine enamel from frost www.frost.co.uk/ and for the block I used one coat heat resistant enamel from international paints, Which came up really well and has lasted.
regards mark
jspicer6
Postby jspicer6 » Fri Oct 05, 2012 8:09 pm
Thanks for the info. I've looked on the Frost link before but wasn't sure which shade of blue to use. Any ideas on which looks best for the Jag head?
mark32
Postby mark32 » Sat Oct 06, 2012 6:09 pm
I dont want to advise you just incase you dont like the shade, what I did was got the catalogue and it shows you the colours and look at the classic tin range they do but what I found was the paint was slightly lighter then what was in there catalogue hope this helps.
Mark
pittet
Postby pittet » Fri Jan 04, 2019 5:37 pm
Hi everyone,
I’ve started restoring my 1961 Mk2 fitted with a 3.8 litre engine. At some point, I will repaint the cylinder head in its original metallic blue colour.
Could anyone provide me with the exact metallic blue paint colour code used by Jaguar in 1961?
Many thanks for your help,
