I recently answered an ad in JE magazine for a 1968 240. The car is a rust-bucket and has not moved for 25 years, having sat under a leaky car port. I've scavenged a number of usable parts from this car, which is otherwise only good for scrap. My question is, is the engine (or at least the straight-port cylinder head) worth saving? The engine is locked solid and does not rotate - no surprise there. The radiator and inlet waterways are empty. The distributor will not move, despite undoing the locking nut and removing the clamp-plate bolt. The HS6 carburettors are seized solid - the pistons do not budge and the throttle spindles are similarly fixed. The exhaust camshaft looks OK from the view down the oil filler. Any thoughts?
Best wishes, David
240 engine for scrap
Re: 240 engine for scrap
Certainly I would have thought that the top end including carbs was worth saving . It is amazing what a good soaking in paraffin or diesel will do to seized components, and in fact 2.4 engines are becoming somewhat rare so that the whole engine is probably worth having
I'd agree with cstorey - it's amazing what a good soaking in a bucket of diesel can achieve. ....also been known to free up seized components.
You'll probably find the engine will un-seize when its broken down into its major components (crank, pistons, block, flywheel, top-end) - each of which will have a value to someone.
Simon
Brighton
Sussex
Brighton
Sussex
Thanks folks, I thought this would be the case. I've suggested the lady gets in touch with a local specialist Jag breaker, but if anyone wants her number let me know (the car is in Surrey). I don't have the time or facility to sort this out - the car has to go by mid Jan, as she is moving house. The car is against a side wall in the far back corner of a car port which is collapsing, so difficult to access. Will need dragging out, I guess.
Best wishes, David
Best wishes, David
