Bell housing
neilcampbell
Bell housing
Postby neilcampbell » Mon Jul 05, 2010 12:18 pm
Hi, I' trying to identify a number of oil leaks from my car (1961) and have posted a separate enquiry in respect of the overdrive unit.
Whilst under the car I noticed two purpose made holes in the bell housing. One seems to show the starter ring and I don't know what the other is. I'm told there should be a plate over the holes. Does anyone know where I can get such a plate and how is it secured.
Many Thanks,
Neil Campbell
ManxNeil
Postby ManxNeil » Thu Jul 08, 2010 1:52 pm
Hi, Neil,
The plate is a flimsy thin metal 'teardrop' shape. The fat end covers the hole and slightly indented in a circular pattern to correspond with the hole itself. The plate tapers to a point where it pivots about a split pin or rivet which locates through a small hole in the bell housing an inch or so to the side of the main hole.
I don't think many plates survive on older XK engines and I only knew what it was because there was one on a spare gearbox in my garage. As it was, I destroyed the plate trying to get it off (the pivot had jammed solid and the plates really are that flimsy) so I made a replacement from a thin piece of aluminium, but I don't really know how effective they are.
Cheers,
Neil
Mk2 3.8; X350 4.2SE
neilcampbell
Postby neilcampbell » Thu Jul 22, 2010 10:09 pm
Hi Neil, Many thanks for the info. I have located such a plate and WATJAG in Derbyshire can obtain them as new approx £4
Again many thanks Neil
ManxNeil
Postby ManxNeil » Mon Jul 26, 2010 1:37 pm
Thanks, Neil, that's good to know, and I'll order one - has to be better than the one I made!
Cheers,
Neil
Mk2 3.8; X350 4.2SE
