Engine Numbers
Posted: Fri Jun 17, 2022 12:41 pm
I have a Mk2 which has been fitted with a 4.2ltr engine which is meant to have come from a Series II XJ6. I have letters and numbers stamped on the top side of the oil filter mounting which is where I should find the engine serial number, unfortunately they do not correspond to anything I can find. The code is AQ 765,Jaguar 4.2ltr is cast into the block above this point. I have also checked forward of the bellhousing on the dipstick side, no joy there. Can anyone shed any light on this?
Thanks, Malcolm
Thanks, Malcolm
