sticking clutch.
RoyN
sticking clutch.
Postby RoyN » Wed May 10, 2017 10:40 pm
Finally getting around to "sorting the Jag " I am concerned the clutch will may well be stuck solid after 28 years.
Would this be normal? Has enyone sorted this without taking the engine out?
no rush as busy trying to sort the Dunlop brakes just now. 1967 S Type.
piman
Re: sticking clutch.
Postby piman » Thu May 11, 2017 7:01 am
Hello Roy,
it's quite possible that it will be stuck. I use the car to free the clutch by depressing the clutch then start it in gear, heel and toe to drive against the brakes, usually it will free in a few feet. Run the engine until it's warm also helps.
PPV
Postby PPV » Fri May 12, 2017 11:25 am
Hi, my clutch sometimes gets stuck over the winter if not used. I use the technique described by Alec but after 28years? Worth a try though, usually goes with a loud noise!
Best of luck,
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
RoyN
Postby RoyN » Fri May 12, 2017 4:25 pm
Thank you gents, your suggestion much appreciated. Just now I am busy waiting for the wd 40 to work it's magic so I can remove the front calipers. But will report back re the clutch.
oldtimer
Postby oldtimer » Fri May 12, 2017 10:41 pm
Roy,
Just a passing thought, the WD in Wd40 means Water Dispersant , try Plus gas (been around for fifty years) for seized / rusted nuts and bolts or even brake fluid ( horrible stuff ) but works.
Martec
Postby Martec » Sat May 13, 2017 8:57 am
Better still, throw the Dunlop callipers in the bin and fit some proper aftermarket brakes.
Look at the pad size compared to modern brakes.
When something modern overtakes you pulls in and slams their brakes on, I hope you are wearing brown trousers!
PS the aftermarket brakes will probably cost the same as 8 new brake pistons and cylinders!!
piman
Postby piman » Sat May 13, 2017 10:12 am
Hello Brian,
the original brakes will lock the wheeels, you can't improve on that. Pad life may be shorter and hard use will probably bring on fade but I think very few of us use the brakes hard and repeatedly on the road?
I take the point about cost however so it depends on what needs doing.
Martec
Postby Martec » Sat May 13, 2017 5:58 pm
Funny I thought you would disagree, I can confirm that the Girling 3 pot calipers (420) can lock the brakes.
RoyN
Re: sticking clutch. Brakes rebuild.
Postby RoyN » Sat May 13, 2017 6:25 pm
Hi again and thank you for your interest.
Plus gas. Never used it, but I will get a can next week.
Dunlop originals. Admittedly not the best design but I can attest to the effectiveness. Before I took the car off the road, it was in daily use and performed well. I have considered the 420..3 pot option and if on inspection the originals are in poor condition then so be it. But as I no longer live a high milage life, I'm quite happy to lock the wheels with the original Dunlops.
As you can see I changed the subject title slightly to save getting into trouble.
thanks again
Roy
piman
Postby piman » Sun May 14, 2017 7:31 am
Hello Brian,
I didn't say that the replacements are not suitable merely that the Dunlops are not as bad as made out for normal everyday driving and if seviceable there is no point changing them?
RoyN
Postby RoyN » Thu May 18, 2017 12:08 pm
Oldtimer
Thanks re Plus gas suggestion. I tried all local stockist without success. But the next time I am on the internet I will get a can, sounds like good stuff. Meanwhile a 24" tommy bar did the trick.
as I have moved so far away from "clutch" I thought it best to continue the saga under a new thread headed "brakes".
Thank you so much for your contribution. Getting to be an oldtimer myself.
Roy
oldtimer
Postby oldtimer » Thu May 18, 2017 10:20 pm
Roy,
Join the club !
