distributor clamp
Posted: Sun Mar 26, 2017 8:10 pm
by Volvo
I am about to fit an Acuspark electronic ignition, should be simple, but getting to the distributor clamp is a bugger - any tips?
Richard
Re: distributor clamp
Posted: Mon Mar 27, 2017 1:56 pm
by PPV
Is this to fit another distributor or just fit electronic system in the distributor? I found when trying to get to mine had to find the right length spanners and got my hand down to the right of the fuel filter area. Got a few scrapes on the hand though! The difficulty was trying to remove it from the engine but fortunately I just needed to turn it to set the timing as I fitted just an electronic system to replace the points.
Let us know if you find a better solution though!
Posted: Mon Mar 27, 2017 6:50 pm
by Volvo
Thanks Paul, like you, the kit I'm fitting is just to do away with the points. I just need to loosen the clamp to adjust the timing when it's done.
Thanks for your help!
Richard
