HI There,
I am currently stripping my first mk2 2.4 and going through the restoration, so far I have rebuilt the rear end, axle suspension brakes, fuel tank, etc and I am presently on the front stripping the suspension and rebuilding that, I am hoping to get the steering and suspension back in the car in a couple of weeks and want to look at the engine and gearbox whilst it is at the PaintShop.
Prior to starting the restoration I rebuilt the carbs to get it started to see what I had to deal with, it started no probs and there were no unusual noises. My question is what can I do to check engine and gearbox operation or wear as I don't want to put it back if they need a rebuild, as I haven't driven the car I have no idea, It is meant to be low miles and a good engine, but that is here say, the oil is immaculate but again here say. I am assuming removing a cam shell and a crank shell would be one idea, as for the gearbox I have no idea other than to turn each shaft for noises.
Any help in testing the quality of the engine and gearbox would be really helpfull.
Many thanks
2.4 manual no overdrive but with uprated carbs
shaungadalla586
peterheywood52573
Re: 2.4 manual no overdrive but with uprated carbs
I am normally a receiver of advise on this forum but here goes.
I was able to strap and engine (not Jaguar 6 cyl) to a pallet and run a compression test. This showed up a cracked valve and then later a stuck piston ring. This can be done on an assembled engine and gives an insight into its condition without disassembly .
Other potential problems such as oil leaks, low oil pressure etc require taking bits off.
Peter
Peter
