I have coverted from positive to negative earth - alternator etc. As a result I have had to disconnect my previously working positive earth clock. I have found clock to replace it from a 1967 car - how can I tell if this is a positive or negative earth OR can I get my existing clock changed?
Electric clock
There should be a warning label stuck to the clock case indicating polarity. If the label is missing there is no way of knowing what the polarity is without dismantling the clock and looking at the diode (the clock from a '67 car should have a diode fitted). The problem with these clocks is that the case is at ground potential; you could possibly use your positive earth clock if you insulate the case from the rev counter and wire the clock in the correct sense, but this is awkward and you might forget later on, so I would not recommend it.
There are three options that I am aware of:
1. Speedy Cables offer a refurbishment service, but I don't know whether this includes polarity conversion.
2. Mike at jaguarclock.com offers an electronic conversion that overcomes the contact failure problem and can include a polarity change. He charges $85 - he did mine and it works very well.
3. Buy a known negative earth clock that works, though these are hard to find (I have one for sale, if you are interested send me a PM)
Best wishes, David
Best wishes, David
electric clock
Would you be interested in selling your positive earth clock on? If so, does it work ok and how much would you want please?
Incidentally, do you mind saying why you changed...what are the benefits of going negative?
Re: electric clock
For me, it's so I can fit a period negative earth FM radio - although I'm looking at this as an option:
http://www.moss-europe.co.uk/Shop/ViewP ... exID=13428
My clock has packed up so I don't need to worry about it.
Simon
Simon
Negative earth
Hi emmb
I wanted to fit an alternator, so the only option is negative earth.
Best wishes, David
Best wishes, David
You can get positive earth alternators..although they are about £100 more expensive. If anyone is interested I can probably dig up some tel no.s.
Also I seem to remember Vintage Wireless do repairs and upgrades to period radios incl postive earth whilst keeping the original fascia. Again can dig up some tel no.s
Sorry to hijack the thread
