Has anybody any ideas on how to make the tail and stop lights brighter on my 240. I use it everyday and so at the moment drive quite a lot in the dark.
I have thought about LED BULBS but believe these are polarity sensitive and I am positive earth. Also are they legal?
Any sugestions would be helpful.
Brighter tail and stop lights
I'd suggest having a look at : www.autobulbsdirect.co.uk
They have a range of upgrade bulbs including LED bulbs and some normal style bulbs which are meant to be 50% brighter.
Not sure on the polarity issue but if you give tham a call i'd imagine that they'll answer any questions / concerns.
I think heat output and extra current / effect on the wiring would need to be considered although the impression I get is that there is no extra heat or draw on current. Last thing you want is melted lenses or burned out wiring !
Please let us know how you get on, i'd certainly be interested in upgarding my mk2 lighting!!
I just tried entering : "positive earth led bulbs" on google and a few responses popped up.
Theres one company slling through e bay and other links to sites.
It will be worth doing the search and looking / reading through for the best buy.
I'd be very interested to hear how the upgrade goes with your car as its something i'm now considering having read your initial post.
Regards, Dave.
Regards, Dave.
Pos Eth LEDs
LEDs are Light Emitting Diodes.
A diode allows current through in one direction only.
LED bulbs are arranged as Neg earth, as this is the common requirement.
Ordinary bulbs will work any way round.
So, to get an LED bulb to work in a Pos Eth car, just cut the wires behind the bulb holder and re-join them in reverse. Ordinary bulbs should not be affected.
HOWEVER!!! This would be a little complex to acheive if you have several bulbs in a holder, utilising a common earth wire. In this circumstance, the whole car would need to be converted to Neg Eth, as is usually required when converting from a Dynamo to an Alternator. This is a much bigger subject. Too big to cover here.
Johnny M
Johnny M
over the xmas break I tried some positive earth LED bulbs bought on Ebay but they did not appear any brighter than ordinary bulbs so cannot recommend them I am afraid. I have found some bulbs which were made for 1970/80 Volvos which are brighter. They are like ordinary 380 bulbs but were designed for the Volvo running lights which were always on and so were a bit brighter for both tail and stop lights.
Hope this helps somebody
regards
regards
LED bulbs in general are not meant to be particularly brighter. Their main advantage is that having no element to break or burn out, they are pretty shock proof, and should last almost forever.
The acual diode genorates little heat and is quite small, so they can be used to provide light in some otherwise awkward places.
I have a fair selection of these that will be used for instrument and internal lighting on my Mk2, and I will be experimenting with side/ tail light use, but for now she's cuccooned up against the weather and won't be unwrapped for a month or so yet.
Johnny M
Johnny M
