Heated rear windscreen rewiring
RichardJM
Postby RichardJM » Tue Dec 13, 2016 7:50 pm
My rhd 1964 Mk2 has a heated rear screen fitted but has no wiring to it. It had some renovation done some years ago including a new wiring harness but the rear windscreen was never connected up. There are 2 wires coming from the screen -one goes to earth and the other is unconnected. I have purchased an illuminated switch to attach to the dashboard but have no idea how to connect it up. I presume it will need a wiring harness.
Can anyone advise how to go about this please.
Richard
JimboV8
Re: Heated rear windscreen rewiring
Postby JimboV8 » Fri Dec 16, 2016 2:36 pm
If you google mk2 jag rear window heater wiring, on the page of pictures there is one showing the wiring. One wire goes to ground and the other goes to a relay on pin 87. Pin 85 on the relay is ground, pin 30 is the power from the battery via a 8A fuse. Pin 86 is the positive switched ignition via the rocker switch.
Hope this helps.
Jim.
RichardJM
Postby RichardJM » Tue Dec 20, 2016 6:41 pm
Hi Jim,
Thanks for your response.
I am having trouble locating the diagram you refer to.
Richard
JimboV8
Postby JimboV8 » Tue Dec 20, 2016 9:16 pm
http://ww2.justanswer.com/uploads/indyt ... fogger.gif
Hopefully you should be able to see it from this.
If this one doesn't help then I'll have a look for a different one.
RichardJM
Postby RichardJM » Sat Dec 24, 2016 12:11 pm
That looks useful
Thanks , will have a look after the festivities
R
