Fuse Box
Buzetti
Fuse Box
Postby Buzetti » Sun Apr 08, 2012 11:17 am
Hi, my '61 MK2 has it's fuse box cover missing - I think it is the one comonly known as 'small?'
Questions are - where can i get a replacement that doesn't cost silly money? (£35 odd seems a lot for a piece of bent steel).
Also, what kind of nut holds it in place (mine also missing)
Will attach photo
Cheers for any advice
Buzz
piman
Re: Fuse Box
Postby piman » Sun Apr 08, 2012 12:22 pm
Hello Buzz,
the nut is a knurled knob and I think it is captive in the cover?
Have you tried any of the Jaguar breakers?
Buzetti
Re: Fuse Box
Postby Buzetti » Mon Apr 09, 2012 1:50 pm
Please could someone advise - what exactly does the Lucas RA6 relay mounted on the fuse box control please?
piman
Re: Fuse Box
Postby piman » Tue Apr 10, 2012 7:04 am
Hello Buz,
isn't if for the horns?
jagman723
Re: Fuse Box
Postby jagman723 » Fri Apr 27, 2012 10:50 pm
I believe the cover does not have a captive knurled knob, that is a separate item. The cover sits over a threaded stud that protrudes from the backplate and the knurled knob screws on to that to secure it.
The only relay I am aware of on this unit is the horns relay.
smiffy
Re: Fuse Box
Postby smiffy » Mon Apr 30, 2012 10:11 am
Hi Buz
Alec and Jagman are correct, the fusebox relay controls the horns. The fusebox cover has a hole in the centre that sits over a stud that protrudes from the baseplate that hold the fuseholder, control box, and relay. A small knurled black plastic knob screws onto the stud to hold the cover in place.
Best wishes, David
Buzetti
Re: Fuse Box
Postby Buzetti » Sun May 13, 2012 4:04 pm
Thanks for the helpful comments, guys. I suspected (wrongly) that relay may be for something more vital than the horns...
Buzz
