UPRATED FUSE BOX ???
david340
Postby david340 » Thu Dec 11, 2008 4:33 pm
I note that my 1968 Jag Mk 2 (340) has only two fuses, a 50 amp and a 35 amp !
Has anyone modified their electrical system to take an additional fuse box for more protection.
There are various aftermarket fuse boxes available, for example those used in kits / replica cars. Alternatively a number of in line fuses could be fitted to different circuits.
I'm still on positive earth and dynamo. Not had any problems but it would seem a sensible precaution for more fuse protection!
sgcronin
fuse box
Postby sgcronin » Mon Mar 09, 2009 2:34 pm
Hi some years ago I modified my fuse box by replacing it with one from a Mini.
It is a much better system than the one originally fitted to the car.
Simon
emmb
Postby emmb » Wed Oct 07, 2009 1:55 am
Hi there
Am in same situation (+earth and dynamo and old fuse box)...was wondering how you got on, whether you changed it or not and what to?
Martec
Postby Martec » Wed Oct 07, 2009 3:28 pm
Hi David,
I bought my MkII as a wreck (worse than PC's Jaguar)in 92 and spent 8 years rebuilding it. I rebuilt it with an alternator (ACR18)and made my own uprated looms (7mm alternator cable) but also split up the feeds across 8 fuses.
On close examination of the old cables they were knackered and lethal.
Auto Sparks make up looms and can make one to suit what you want. At a pinch you could fit an alternator and run in new cables as a separate loom to feed the battery. Also possibly split the feed from an aftermarket 8way fuse box.
