Speedo pinion drive gear needed for 3.4 mk 2 with dg gearbox
Posted: Sat Apr 19, 2014 9:58 pm
by RichT
Hi all
Having fixed my gear box............... Now the speedo!
Just a shot in the dark, I need a pinion (driven) gear for the speedo cable in a 3.4 litre mk 2 with a dg 3 band box think 22 teeth any help appreciated
Rich t
Re: Speedo pinion drive gear needed for 3.4 mk 2 with dg gea
Posted: Fri Apr 25, 2014 2:55 pm
by Martec
Hi Rich,
As no one has answered, have you tried G Whitehouse Autos, he had a very good name a few years ago.
http://gwautos.com/
Posted: Tue Apr 29, 2014 10:24 pm
by RichT
Hi Brian
I eventually got one from them at a cost of seventy five squids
Old speedo drive housing was worn allowing cog to rattle itself to death
With new cog and cable had to make 3 mm spacer to make it work, I think that's why previous cog got chewed
Fingers crossed it will work for a while so far so good
All the best
Richard
Posted: Thu May 01, 2014 4:32 pm
by RichT
When fitting pinion with David manners sourced cable I had to washer out the pinion to remove end float, spoke to graham White House about this and he thought it was fine
Just to say he could not have been more helpful. I will try to post a photo in case anyone else has a broken or wavering speedo on a dg box although I suspect a lot of the autos have long been converted
Photo won't upload from ipad so contact me in the case of anyone having the same problem
Posted: Thu May 01, 2014 8:07 pm
by Martec
I'm glad to hear you got it fixed.
